Hi all.
It's my first time using this software. I have an SVCD that I have converted, but I find that 352x480 is not acceptable in the DVD burning software I have. It demands 720x480. So...I redid the job at that resolution. While the file is accepted by my software, Dazzle's DVD Complete, the image has been thrown up into the upper left hand corner by SVCD2DVD.
Why is the image not centered?
Thanks in advance.
Take your first video, the one in 352x480, and use DVDPatcher to patch the resolution to 720x480, which will not even take a second.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
352x480 is CVD. As far as I know it's accepted by svcd2dvd. Reencoding it (making it bigger) will make the picture blocky and ugly. If your burning software can't handle it, then change. Or burn your VIDEO_TS and AUDIO_TS folder as UDF 1.02 if you have that option in your software. That's is if you author with svcd2dvd .Originally Posted by apollo1980
Megui Resolution problem
By thezanny in forum Video ConversionReplies: 3Last Post: 9th Mar 2011, 09:34 -
HD Movie resolution problem
By Penicillin in forum DVB / IPTVReplies: 3Last Post: 21st Jul 2010, 16:18 -
Half D1 resolution problem
By sebrame in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 10:18 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 03:47 -
HD TV Resolution Problem
By jemoto in forum DVB / IPTVReplies: 9Last Post: 29th Mar 2008, 05:45
