Results 1 to 14 of 14
8x
  1. is there any where on this earth that sells a 8x dvdr? or a dvdrw? i have a 8x burner but 4x is the fastest dvdr i can find :P
    movies do we watch them or do they watch us?
    USA
    No, none are sold in the UK, only everywhere else. Try a Google search for 8X DVD media; That may give you a few sources. 8X is still new, so it takes some looking. DVDRW 8X, no not likely. RW media will always be slower than R+ or R-.
  3. Member HAMP's Avatar
    Jan 2004
    Which 8X burner do you have? Some 8X burner's will make 4X media burn @ 8X. I have a Plex 708A and I buy TDK and Verbatim 4X +R and they burn @ 8X
  4. iv got a dvd dual.its from the computer shop(thats the shops name by the way lol).i picked it up for 80pounds.its 8x but it takes upto 30mins to burn a dvd.im using memorex dvd+R and tdk-R
  5. Member HAMP's Avatar
    Jan 2004
    When you say it takes an 1/2 hour to burn, are you talking from ripping and burning being total time of a 1/2 hour or just the burn part? What is the name of the burner?
  6. Weird.. we had 8x media out several months before 8x burners
    were available even in Japan. There must not be sufficient demand
    in the UK for such media - strange!
  7. http://homepage.ntlworld.com/emperordalek/
    I found this nice page while trying to find cheap media for myself and my friends (living in Norway, your media is far cheaper )
    Everything with Ritek R03 dye is 8x.
    http://www.rivierapublishing.co.uk/acatalog/copy_of_RITEK_8X_DVD_R.html
    http://www.lynxdv.com/catalog/product_info.php?cPath=23&products_id=58
    http://arndalemedia.co.uk/product_info.php?products_id=87
    etc etc.
  8. Concerning 8x media. Does anyone know if there is any real difference in results or quality of a DVD burn doing a 4x media burning at 8x speed vs burning using "True" 8x media?
  9. I've seen posts from people scanning with kprobe which says that there's a peak in p1/p2 errors on the disk where the writer changes speed (not that there's read errors).
  10. It takes me 30mins to burn all the ripped files to cd after i have ripped the movie using dvd shrink.iv got it on 4x speed wich is the max my dvd-r,s will go.if i had a 8x dvd-r,s i could get it done alot faster.
  11. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    Its obviously burning at 2x.
    can't you get it to go any faster?
  12. i dont know how iv got it set to max speed setting on software im using.
  13. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    did you update the firmware?
