i have a problem with this system idle process (ctrl+alt+del). im using winxp prof (1gig of ram & everything updated from video card) and everytime i play any kind of video file such as avi, mpg, etc., the system idle process uses less than 50% while the media player using 80-100%. thats why the video file lagg but is there any way u can fix these problem.
suggestion?
thanx n advance
I think you have a problem with your video card. You might try to substitute a different card. Even a slow system should be able to play most video without problems.
The system idle process on your system is behaving properly.
I checked the utilization used by media player on my system and it varied between 5 and 35% CPU utilization (I was playing back an MPEG2 at the time).
Your problems could include video card, drivers, interrupt settings, codec problems, or hardware acceleration being disabled or misconfigured.
For starters, try a different media player (the DivX player for DivX videos, or Media Player Classic for example). Also, download and fire-up gspot to check which codec is actually attempting to decode a certain file type.
Perhaps you've got conflicts or a bad codec installed. Only install the codecs you need -- sometimes they can fight with one another and create problems. -
might wanna scan for virus's also, sounds kinda weird but i just disinfected my friends computer which had 2 trojans, and some really bad spyware running on his computer and it did some weird stuff to it.
i did try using media player classic, powerdvd, windvd, gspot etc. and the outcome are still the same!
Problem with recording apps hanging after sitting idle under XP Pro.
By brassplyer in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2011, 07:22 -
ReSize MKV - HandBrake hanging on new system (process stopped)
By Raycaster in forum Blu-ray RippingReplies: 1Last Post: 10th Sep 2010, 05:42 -
Cooling Solutions - *Solved & updated* Problems w/overheating & idle temps
By Noahtuck in forum ComputerReplies: 21Last Post: 28th Jul 2010, 21:30 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54
