  1. I have done a few backups using the guides.I have a query reguarding the settings in file mode in particular the settings
    1-Remove IFO/BUP RC protection
    2-Remove IFO/BUP RCE Protection
    3-Remove IFO/BUP PUOs
    4-Remove VOB/PUOs
    5-Patch M2V Timecode
    one guide says to chexk 1,2&5 the other to check them all.What difference will this make as I have done it both ways and both seem to work
    All help greatly appreciated
  2. At the beginning of some DVDs you are forced to sit through all of the FBI warnings, etc... you can't skip them, forward through them or even access the main menu until they have finished playing.
    If you want the option to skip the warning screens, forward through them or access the main menu immediately, select all five settings in DVD Decrypter.
  3. thanks for clearing that up
    i appreciate it
