Results 1 to 9 of 9
  1. when i use dvd decryptor to rip i always do movie only selecting main movie files and it has always worked but in the latest versions of dvd decryptor there is the option to select main movie files+ifos
    whats the difference here and why do you now need the option for all ifos .
  2. cmon 62 views and no answers
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    People won't reply if they don't know the answer.
    If in doubt, Google it.
  4. Member wulf109's Avatar
    Jul 2002
    The option is still there,Settings-FileMode
  5. Originally Posted by jimmalenko
    You did
  6. Human j1d10t's Avatar
    Feb 2003
    California, USA
    You did
    That's because he knew the answer to your question(?) about why there had been 62 views, and no answers
    As for your "original" question, what version of DVDDecrypter are you using? 3.2.1.0?
    I'm using version 3.1.7.0, and I can copy/decrypt the VOB and IFO files all at once by clicking on the Tools menu, then Settings, then the IFO mode tab, then in the Options there is a check-box that says "Copy IFO File"... Check that box...
    Things may have changed between the versions, but check the settings - that's usually the best place to start.
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
  7. You can double click that IFO file & see what it does.
  8. Originally Posted by red lion
    Grow up, no one owes you anything.
  9. @ toronto098 i wont waste my time with a reply to your last post..
    @ j1d10t im using version 3.1.9.0 and i can backup my dvd,s with no problems doing it the way i always do (movie only) using "select main movie files" but there is now another selection on the dropdown menu calld "select main movie+ifo,s" just would have liked to know why this has been added
    ie is it better or were people having problems without all the ifo,s
    also @handyguy i will try and see what difference the added ifo,s make
    thanks
    btw maybe i was a little impatient but i like to know all the settings..
