I would like to encode all my mpeg footage in 1 go, import it into Encore, set the chapter points and then have the footage play upto chapter point 2 before going back to the menu. Then play between chapter point 2 and 3 and back to the menu and so on. Is this possible??
I am aware I can use a number of timelines, but this means I have to encode to MPEG2 in batches as opposed to doing it in 1 go.
yes you can do this. when you create a chapter point, it should say somewhere what you want to happen after the chaper is over, and you can then just select go back to menu. it would rpobally be in the properties or something.
loop point/transitions glitch in adobe encore authored blurays
By tikigod19 in forum Authoring (Blu-ray)Replies: 1Last Post: 31st Oct 2011, 06:40 -
Encore CS4 loop point problem
By sebaz in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Jul 2010, 14:14 -
Shifting Chapter Point on DVD without reauthoring
By Instant Martian in forum DVD RippingReplies: 4Last Post: 4th Sep 2009, 10:10 -
Chapter Separators with Adobe Encore
By LAM_ in forum EditingReplies: 2Last Post: 22nd Oct 2008, 10:23 -
How can I set resume mode in Adobe Encore?
By Sean_ve99 in forum Authoring (DVD)Replies: 0Last Post: 26th Sep 2007, 16:10
