as far as i can tell, this site is useless. all the guides i have used ask for a file i dont have. no body knows what video_ts.inf is, copytodvd guide dont say anything about it. ive asked, searched, posted and i havent learned anything new. how hard is it to take a mpeg file and make it ready to burn as dvd? im posting this for no real reason, nobody ever responds anyway
You are in breach of the forum rules and are being issued with a formal warning. One topic is enough. If you want to add more information reply to or edit your first post.
/ Moderator Baldrick
Closed Thread
Results 1 to 10 of 10
VMGI stored within VIDEO_TS.INF file within VIDEO_TS directory.
http://www.mpeg.org/MPEG/DVD/File/File.html
took me 1 minute to find this info on google.I think,therefore i am a hamster.
If you have an mpeg file you need to make sure it is DVD compliant which means using an encoder like TMPGenc PLus .
This creates 2 files one is a m2v video file and one is a wav audio file.
These then need to be authored using authoring software i.e. TMPGenc DVD Author to create a VIDEO_TS folder which you can then burn with burning software.
That is a very simplified version of events.
A couple of points reguarding your previous posts - Virtualdub is for editing AVI files not MPEGs . Your post reguarding your burner was answered , the concensus seemed to be that your bundled software conflicted with Nero , Your question about .INF was answered . And you last few posts were in the last hour or so . If you want to do video editing it requires a lot of patience , you sometimes have to wait a while for replies but they will come.
I have been doing this for a while now and I didn't know whay an .INF was until I read your posts .
Dude, pull your head outta your ass and do some more reading.
There are many, many ways to author an MPEG. You don't HAVE to use CopyToDVD.
Have you tried other software ? TMPGEnc DVD Author perhaps ?If in doubt, Google it.
You make it when you author your dvd(making the dvd structure and optional menus, chapters...). Copytodvd can only burn, so use an author tool as jimmalenko says.
https://www.videohelp.com/guides.php?howtoselect=3;6#3;6
https://www.videohelp.com/tools?section=2#2
And you already got an answer in your first post.
And one topic is enough.
https://www.videohelp.com/forum/viewtopic.php?t=212070&highlight=
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
MPEG II to MPEG (DVD): Transcode or reencode?
By Jeroen1000 in forum Video ConversionReplies: 8Last Post: 12th Feb 2009, 17:44 -
MPEG-1 to MPEG-2 to DVD Advantages/Disadvantages?
By louv68 in forum Video ConversionReplies: 4Last Post: 7th Jul 2007, 16:51
