Results 1 to 9 of 9
  1. hello, i have a home video and i'd like to create subtitles for that video that i can turn on and off as i want and then burn the video in a dvd. anyone can help me out doing this?
    all the tutorials that i find was for work with subtitles ripped from dvd. I want to greate them.
    Please help me.
    thx
    Dec 2001
    You can get a subtitle plugin for VirtualDub.
    http://www.virtualdub.com/virtualdub_filters
  3. Originally Posted by chaseru
    Yeah, start reading the GUIDES and check the TOOLS section.
    chaseru: You can't make selectable subtitles with virtualdub.
    You can use any of these authoring tools(most have built in subtitle editors):
    https://www.videohelp.com/tools?toolsearch=&section=&orderby=Name&convert=&dvdauthorfeat...+or+List+tools
    but most are very expensive, ifoedit is free but can't do much advanced stuff. Make the subs in subtitle workshop and export to srt and use srt2sup and you can author in ifoedit.
    You can also use subtitle workshop to make subs for most other authoring tools, like for Ulead DVD Workshop, DVD Maestro, Sonic Scenarist, Sonic DVD Producer.
  5. Member daamon's Avatar
    Melbourne, Oz
    Hi v1p0n3,
    I will soon be looking to do the same. After a bit of trawling recently (in preparation), I found these that I thought were the most promising looking:
    https://www.videohelp.com/guides.php?guideid=475#475
    https://www.videohelp.com/forum/viewtopic.php?t=179271&highlight=
    https://www.videohelp.com/forum/viewtopic.php?t=197344&highlight=
    Hope that helps. If you get to use 'em before I do, please post back with your thoughts, pitfalls, experiences etc. Ta.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Feb 2003
    Copenhagen
    To avoid some of the mistakes i have made:
    In srt2sup, remember to write down the colors given, and only do the settings under "global settings" in the menus!
    In ifoedit, write the colors in hex values as described in the guides, and remember to save!
    These was just the things i did wrong in my first DVD´s..
    Regards
    Chr
    Where is the Deadly Viper Assasination Squad, when you need it ?
  7. thanks for your replys
    i'll test this methods during the weekend.
    by the way... you guys write your subs manualy?
    thx
  8. Hi,
    A couple of bit tips from the author of Srt2Sup!
    1) Make sure you use 4 different colours for eact of the elements [text][outline][Antialias] and background, don't worry what colours you use as we will fix this in tip 2)
    2) Use my SupRemap tool to set the colours in the IFO file!
    You can get the latest Srt2Sup a4.03 and SupRemap a4.04 from www.shipleys.eclipse.co.uk
    Regards
    Srt2Sup
    Feb 2003
    Copenhagen
    Originally Posted by [url=https://www.videohelp.com/tools?tool=288#comments
    srt2sup[/url]]
    Regards
    Srt2Sup
    I have just tried it, You are a genious!
    Setting These colour values was the only thing, that was a little tricky...
    Thanks for all the work you have put in to these programs!
    Best regards
    Chr
