Hi,
I am having a problem with svcd2dvd. I have many movies backed up on cd-r's. First I rip the mpg file using isobuster by choosing the extract but filter option. It rips the mpg file no problem, but when I go to join them and create s dvd SVCD2DVD freezes when it gets to multiplexing elementary streams. I tried every cd-r I have I get the same results. Is there a fix for this? BTW I use the default settings. Is there another program I can use to join 2-3 mpg files and burn on dvd? This program works flawlessly on my bin/cue files.
It has been stuck on this multiplexing elementary streams for about 6 hours now still no luck. Can anyone tell me what I am doing wrong?
Can you put your logfile in the forum. Maybe we can figure out what's wrong.
guido -
I prefer vcdeasy to extract mpegs from cd's. It gets it right all the time. I get the same problem you describe sometimes with bin files. Looks like vcdgear is'nt up to it. Anyway, why join the files? If the mpegs are cut precise it will play seamless on your standalone. There's also a possible problem with audio synch when joining.Originally Posted by Rubberbandman
Yep, it extracts the mpg file out of the s()vcd. You could also try to change the ripper in svcd2dvd from vcdgear to vcdxrip. 4 hours to do a dvd?! At most it takes 1 hour for me, normally 40 minutes. First of all it's very important that you run defrag now and then.(Diskeeper is very fast) Because if your harddisk is heavily fragmented you could end up with 4 hours to make a dvd just because of that reason.Originally Posted by Rubberbandman
Secondly try all the fastests options in svcd2dvd if you have'nt already done so. Then it's your capacity of your harddisks. If you have ata 100 you should have like 40-50 MB/s in Nero speed test. An empty harddisk is the ideal, of course. It's about 30% faster than a half full defragged one. -
yes my pc is very tweaked, I defrag every 2 days. I am using a maxtor 120 gig hd 7200 with a 8 m cache. So I know thats not the problem. I use nero smart and add custom audio and video, as well as new menu's That what takes so long.
Trouble ripping DVD with subtitles
By stig in forum DVD RippingReplies: 9Last Post: 22nd Feb 2012, 06:08 -
Trouble with DVD Ripping: Need Some Recommendations
By charmedlife417 in forum DVD RippingReplies: 9Last Post: 28th Sep 2011, 22:44 -
Trouble ripping HDTV (.ts)
By Julllie in forum DVB / IPTVReplies: 4Last Post: 7th Mar 2011, 11:12 -
Trouble ripping video and/or audio
By dexter30 in forum DVD RippingReplies: 8Last Post: 26th Feb 2010, 12:06 -
Having trouble ripping DVD to avi
By jsbenson in forum Newbie / General discussionsReplies: 9Last Post: 29th Aug 2009, 22:44
