I am not sure of the techical name of the jilted movements I am getting from my TMPGEnc encoded SVCDs but I hope there is a way to smooth out the results. I would also appreciate knowing what this is called...for instance, if there is a scene where a car is moving off into the distance and in my resulting SVCD it appears to kind of start and stop and start and stop and so on. I would like to know what I can set in TMPGEnc to smooth that out where it will look normal and not jilted.
Hey Mr. Taggert...ya want some beans?
Well, if your source is NTSC and you convert it to PAL (or vice versa) your gonna have a "jittery" picture.
Use G SPOT to see what format your source is .
if your source is 29,97 fps or 23,976 then convert your file in NTSC format
if your source is 25 fps then convert your file into pal format
this worked for me so give it a try -
I don't know where you got the idea that I am converting PAL or NTSC. My player plays both so I am not doing that. I am just trying to get rid
of the jumpy or jittery video and replace that with smooth movement.Hey Mr. Taggert...ya want some beans? -
He got the idea that you are converting PAL or NTSC because you are producing a SVCD and therefore using TMPGenc to create an MPEG file which is going to be either PAL or NTSC. You are converting from something (but you don't say what) which is gonna be either PAL or NTSC. My guess is some kinda d/l'd Divx/Xvid file, which is gonna be PAL or NTSC.Originally Posted by saladonyourlincoln
Use GSpot to identify video details and encode accordingly in TMPGenc. If its a 29.92 fps film use the NTSC template. If its 23.97 fps use the NTSCFilm template. If its 25 fps use the PAL template.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2008, 00:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 09:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 05:38 -
FitCD / TMPGEnc question
By Seroster in forum Video ConversionReplies: 4Last Post: 3rd Sep 2007, 13:34 -
TMPGEnc XPress 4 Question
By Anakin in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 00:08
