Product Link
use a $15 of anything coupon (in store/phone only) and get it down to $10. Code: 23773
It works on the phone, i ended up buying 2 packs and paper clips to get it over the $50 free delivery limit (they were gonna charge me $8 for delivery, even though I chose in store)
Total came out to $37.85 including tax for 2 packs. Not smoking hot, but not too shabby.
Even hotter if u can use the coupon code in store and just get one spindle. I will have to give that a try later this week.
Angela
Thanks Angela. Would you mind getting the media code in DVDinfoPRO and posting it? I'm curious as to who made them.
Pull! Bang! Darn! -
Sure thing, I will do that as soon as I get the DVDRs (after i update my dvdinfopro first).
I got the DVD+Rs and on the media list it lists them as RICOHs though, hopefully that will be what im getting.
Angela -
Thanks for replying, you got a good deal for RICOH DVD+Rs. I got a spindle of the DVD-Rs and they are CMC MAG AF1. Not what many would consider the most desirable blanks, just so you know that's what you might get. I've had trouble with CMCs when I push maximum disc capacity. No, I'm not returning mine, I'll just burn 'em at 4.0 to 4.1G.
Pull! Bang! Darn! -
this is wut DVDInfo tells me:
Region information N/A not a DVD-VIDEO
Manufacturer ID cannot be read
Format Capacity Not Formatted
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type Unknown
Media Type DVD+R
Media Id Code Speed Unknown
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Linear Density Blank Disc
Track Density Unknown
Number of Layers 1
hope that's not a bad sign.
If you buy over $50 and get free delivery, u can return the other items, then its back to $10 for the spindle. A little extra work if you wanna do it.
my roommate wants me to burn things for her so she's buying my 2nd pack off me at the 24.97 price, so it works out for me.
Angela -
Hey, after you burn a disc, check with infopro again.
On a side note.. At my local office max they have a 100 pack of ridata +R for $89.00. I will post this on a new thread. They also have 25 pack fuji for $29.00 if anyone is intersted.
STAPLES DVD-R Discs
By Frank-0-Video in forum MediaReplies: 8Last Post: 7th Jun 2011, 18:26 -
Just a reminder: Windows 7 Upgrade coupon expires on February 28, 2010
By usually_quiet in forum ComputerReplies: 0Last Post: 20th Feb 2010, 23:57 -
What's a good coupon eligible Digital Converter Box? There are so many now.
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 17Last Post: 22nd Jun 2008, 19:37 -
Where is the coupon application?
By moviebuff2 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2008, 14:15 -
shop4tech.com 10% coupon
By lordsmurf in forum MediaReplies: 0Last Post: 20th Aug 2007, 20:05
