  1. Hi there people,
    Looking for some help here which i must add i have not needed much help with this program. I put the die hard trilogy with menus to 1 dvd no problems, now i have the star wars collection. Attack of the clones converted to dvd no problem the other 3 films run so far then an error comes up saying cannot find file. Here is a couple of examples:
    And any help would be much appreciated
    Starting SVCD2DVD: v1.51.2.0
    Begin time: 12:10:55
    ******** Ripping BIN images to get mpegs (VCDGear )
    Analysing File: H:\Star Wares\1 Phantom Menace\VIDEO_TS\Video1 Phantom Menace_FIXED.mpg
    ++ WARN: packet length beyond buffer (pos = 18 + size = 2306 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
    ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
    Analysing File: H:\Star Wares\1 Phantom Menace\VIDEO_TS\video2 Phantom Menace_FIXED.mpg
    -->Processing 2 mpeg files.
    ############### New MPEG File ###############
    Type: VCD
    Horizontal Res: 352
    Standard: PAL
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    (Total size: 689MB, Duration: 00:03:17, Rate(MB/Min): 208.85)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    (Total size: 113MB, Duration: 00:01:24, Rate(MB/Min): 79.87)
    ******** Multipexing elementry streams
    INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    **ERROR: [???] File H:\Star Wares\1 Phantom Menace\VIDEO_TS\Video1 Phantom Menace_FIXED_DVD.mpv unrecogniseable!
    INFO: [???] File H:\Star Wares\1 Phantom Menace\VIDEO_TS\Video1 Phantom Menace_FIXED_DVD.mpa looks like an MPEG Audio stream.
    **ERROR: [???] Unrecogniseable file(s)... exiting.
    System.IO.FileNotFoundException: Could not find file "H:\Star Wares\1 Phantom Menace\VIDEO_TS\Video1 Phantom Menace_FIXED_DVD.mpg".
    File name: "H:\Star Wares\1 Phantom Menace\VIDEO_TS\Video1 Phantom Menace_FIXED_DVD.mpg"
    at System.IO.__Error.WinIOError(Int32 errorCode, String str)
    at System.IO.FileInfo.get_Length()
    at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
    at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
    Begin time: 12:48:38
    Analysing File: H:\Star Wares\3 Empire Strikes Back\VIDEO_TS\video1 Empire Strikes Back.mpg
    Analysing File: H:\Star Wares\3 Empire Strikes Back\VIDEO_TS\video2 Empire Strikes Back.mpg
    Type: VCD
    Horizontal Res: 352
    Standard: PAL
    Erroneous packet size, skipping
    (Total size: 560MB, Duration: 00:03:19, Rate(MB/Min): 168.47)
    (Total size: 89MB, Duration: 00:01:15, Rate(MB/Min): 70.66)
    **ERROR: [???] File H:\Star Wares\3 Empire Strikes Back\VIDEO_TS\video1 Empire Strikes Back_DVD.mpv unrecogniseable!
    INFO: [???] File H:\Star Wares\3 Empire Strikes Back\VIDEO_TS\video1 Empire Strikes Back_DVD.mpa looks like an MPEG Audio stream.
    System.IO.FileNotFoundException: Could not find file "H:\Star Wares\3 Empire Strikes Back\VIDEO_TS\video1 Empire Strikes Back_DVD.mpg".
    File name: "H:\Star Wares\3 Empire Strikes Back\VIDEO_TS\video1 Empire Strikes Back_DVD.mpg"
    Begin time: 18:52:38
    ******** Ripping SVCD images to get mpegs (VcdXRip)
    Analysing File: E:\Star Wares\4 Return Of The Jedi\VIDEO_TS\Video1 Return Of The Jedi.mpg
    Analysing File: E:\Star Wares\4 Return Of The Jedi\VIDEO_TS\video2 Return Of The Jedi.mpg
    Type: VCD
    Horizontal Res: 352
    Standard: PAL
    (Total size: 561MB, Duration: 00:08:32, Rate(MB/Min): 65.72)
    (Total size: 90MB, Duration: 00:03:15, Rate(MB/Min): 27.61)
    **ERROR: [???] File E:\Star Wares\4 Return Of The Jedi\VIDEO_TS\Video1 Return Of The Jedi_DVD.mpv unrecogniseable!
    INFO: [???] File E:\Star Wares\4 Return Of The Jedi\VIDEO_TS\Video1 Return Of The Jedi_DVD.mpa looks like an MPEG Audio stream.
    System.IO.FileNotFoundException: Could not find file "E:\Star Wares\4 Return Of The Jedi\VIDEO_TS\Video1 Return Of The Jedi_DVD.mpg".
    File name: "E:\Star Wares\4 Return Of The Jedi\VIDEO_TS\Video1 Return Of The Jedi_DVD.mpg"
    Please some help here as i have the alien trilogy to do next, and would so much appreciate it going smooth
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    The files are not bing processed as the have a strange mpeg structure. Can you re-download SVCD2DVD as the latest version may correct the structure if it can. That said you may have to re-encode. You may want to try the other demuxer too after you have got the latest.
  3. isn't 1.51.2 the latest version? That is what I am running, if it's not the latest, it might solve my issues also.
  4. Thank you chrissy boy,
    Will go try what you suggested
    Plod
