PROBLEM:
I captured VHS to PC to DVD - when I play it on the TV I see horizontal flicker lines only in the bright color - so if say red was on the left half of the screen - then read would have horizontal flicker lines in the left half of the screen. This happens with bright colors - yellow, read, bright blue - not dark blue not black or white- on people's flesh.
BACKGROUND:
I own an HP m270 machine - specs are here:
http://h20015.www2.hp.com/content/common/manuals/bph08498/bph08498.pdf
WHAT I DID:
I Captured with ARCSOFT...
CONSTANT SETTINGS:
A) VIDEO DECODER: NTSC_M (sidnal1 lines 525)
B) CAPTURE CARD HAUPPAUGE V1.17.250.21153
C) AUDIO SETTINGS: CRC STATE/ON, Sample Rate/48Khz, Output mode Stero.
D) VIDEO PROC AMPS - all defualts
E) VIDEO PROPERTIES: GOP STRUCTURE N:15/M:3
F) VIDEO PROPERTIES: Bitrate mode = variable bit rate (max 8) - played with it some and it did not cause my problem.
USED ULEAD to RENDER DVD files and burned with NERO
ITEMS PLAYED WITH AND RESULTS:
Video Size:
320-240 (mpeg1) - had less calrity, pixalation - took care of the horizontal flicker in the picture. Aslo text is shifted to the right instead of centered and some is off the screen on the right.
720x480 - has the horizontal flicker on the bright colors, but no pixlation - very clear and sharp.
Used TMPGENC - to create 704x 480 reduced the horizontal flicker on the video.
Playing wit audio bitrate - makes me think that the 384 KBPS is better for stero.
QUESTIONs:
1) How do I get no pixalation and horizontal flicker in the bright colors and keep a decent calrity (sharpness)
2) are there other VIDEO size settings other than the ones I tried above?
Any help will be greatly appreciated!!!
Results 1 to 1 of 1
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
My DVD don't show the picture, time line and subtitle on DVDSubEdit
By larrycenter2006 in forum SubtitleReplies: 3Last Post: 21st May 2009, 23:11 -
Line thickness and color oversaturation
By waefwaeefwaefw in forum RestorationReplies: 71Last Post: 27th Jan 2009, 08:01 -
Expanding AVI to eliminate line flicker
By yukon33 in forum EditingReplies: 1Last Post: 18th Feb 2008, 10:28 -
command line program to show dvd info?
By skeptic_always in forum LinuxReplies: 1Last Post: 20th Aug 2007, 20:03
