    Aug 2002
    South Florida
    Will DVD 352X480 play on external DVD Players hooked up to a TV, or must it be standard DVD specs only?
  2. Perhaps I am not understanding what you are asking...352x480 is a standard DVD resolution for NTSC so I would say Yes
    No, I'm from Iowa. I only work in outer space.
  3. Yes, I have made half dozens DVD using 352x480 and all these discs play fine in stand alone DVD players.
    ktnwin - PATIENCE
    Aug 2002
    South Florida
    Thank you both. I know 352X480 is a standard, but I would not assume, apriori, that it would necessarily work on a stand-alone player. Now, I know
  5. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Just beware that although 352x480 will play on a stand alone DVD player it must be 4:3 ratio as a stand alone DVD player will not resize a 16x9 anamorphic DVD witha resolution of 352x480
    That only works as it should when you use 720x480 and I think 704x480
    These are of course NTSC resolutions.
    Same applies to PAL although it uses 576 instead of 480 for the height
    - John "FulciLives" Coleman
    P.S.
    You can make 352x480 16x9 anamorphic if you want but it will only look proper on a 16x9 TV (or a 4:3 TV that has a 16x9 mode).
