Hi,
Is there a way to remove menu buttons in TDA? I hate having the "go to first" and "go to last" page buttons on menus, can I somehow remove these?
Thanks!
Not that I'm aware of.
You can resize the buttons and place them outside the safe viewing area but that's about all.Just shut up and listen dumbass -
That is what I just did, placed the buttons outside of the safe viewing area but when I play it in my DVD Player, would the selection still not go over it but I just cannot see it?
Thanks! -
You can use a tool called MenuEdit to remove buttons and change the yellow highlight that is default in TmpegEncDVDAuthor.
Just author your DVD to a folder on the hard disk and make the changes before you burn.
More info in the tools section - link below
https://www.videohelp.com/tools?tool=227
Any free tools to author DVD structure with menu buttons?
By p23185 in forum Authoring (DVD)Replies: 1Last Post: 1st Mar 2010, 17:03 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
