Hi,
I have 3 videocapture devices. One is an old Iomega Buzz Multimedia "box" (has an internal proprietary SCSI controller with an external box to plug things into), a Dazzle DVC-USB (not the 80 or 100 or 150) and a Winfast xp2000 tv tuner card. i was given the first two and bought the tv tuner for obvious reasons. I am trying to convert Videotapes into VCD format. I want good quality but I am not a gourmetThe Buzz does a raw data conversion and needs hours of work after the conversion. The Dazzle box, as much maligned as other models (i.e. 80, 100, 150) are, did a pretty good job the first few times I used it - a year ago - but now when i try to install it, the sofware insists that I am missing "msjet4x.dll". I tried to assure the computer that the file was there - I even offered to set the computer up with a nice handsome P4, but it wouldn't believe me
I have an ASUS MB with a 1.2 Duron on it now - hope to upgrade to a 2400 or more AMD XP in a couple of months, 256 MB of RAM and 200 GB of hard drives, with win 98se. My questions:
1. Can I get different software for the Dazzle? I look on Dazzle's (now Pinnacle's) website and they keep insisting my product came with a program called "Moviestar", which it did not. It came with a program called Dazzle's DVC creator internet edition version 3.6, which worked pretty well - when it worked. About 30% of the time I had to reboot my system after the first attempt to use it. I was looking on your site and others and there are several freeware programs to use for videocapture but I don' t know enough about the device to know which kind of program I need.
2. Which device (of the three) do you think will give me the best results - also needing the least amount of trouble?
Thanks for any help you can provide. Also thanks for some great tutorials. Sometimes I feel after I read your website that I am working on getting a Ph. D.
Tom
Results 1 to 1 of 1
Need help choosing a converter
By fatcharlie in forum Video ConversionReplies: 9Last Post: 28th Feb 2011, 12:34 -
Need help choosing a HDTV
By drifter666 in forum DVB / IPTVReplies: 25Last Post: 1st Feb 2011, 20:09 -
Choosing Hardware and Software Help Needed
By The OrangeLemon in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2010, 17:05 -
Choosing Music
By Flaskpost in forum Newbie / General discussionsReplies: 13Last Post: 24th Apr 2009, 22:51 -
Choosing a Laptop
By Nitro89 in forum ComputerReplies: 16Last Post: 13th Sep 2008, 07:15
