Hi
I am a newbie. I recently purchased a DVD9 Dvd. It is playing well in Standalone DVD Player(which is connected to a TV). But this DVD isnt playing on my PC. I have Samsung DVD Rom Drive. The rest of the DVD's are playing except for the DVD9. WinDVd,PowerDVD,WM9 dosnet recogonize the format atall.. moreover..when i go into the Video_TS folder all the files says 0KB Size. but hte dvd shows 4.3 GB in Size..
can anyone help me on this one please
My PC Config is
P4 1.7 Ghz
RIVA TNT2 M64 PRO (32 MB)
Creative SoundBlaster Live 5.1
thanks in advance
/KK
When you say it doesn't recognise the format , most commercial DVDs are DVD9 that just means it is a dual layer disc . If you are reading that the disc capacity is 4.3 GB That would be a DVD5 .
Your question is somewhat confusing.
Can you play commercial DVDs on your PC ie Original films bought from shops?
Is the film you are having problems with an original film or a copy?
It is strange for someone to say I purchased a DVD9 .
You might say I bought a DVD Film today and it wont play.
Where did you get the information that it was a DVD9 from ?
DVD9 cannot play on SONY DVP-NS55P
By techworld in forum DVD & Blu-ray PlayersReplies: 15Last Post: 1st Aug 2018, 22:45 -
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 21:34 -
i got an dvd9 movie and it couldnt play on my home dvd player
By techworld in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 06:57
