After attempting to upgrade to the new release of ATI software, I lost my ability to record audio during capture. I can hear it while recording, but no volume on playback with any of the DVD players. (Video is perfect)
Compaq 2.6 gig processor 528K ram 260 gigs of fast HD
WIndows XP (current)
What ATI driver should I focus on?
Any ideas are appreciated.
Deleted everything and tried going back to 8.1. No audio
Hint:
I may have loaded the wrong drivers at the initial upgrade.
I think I now have the right drivers downloaded. I think!
Frustrated
DVD technology is totally different technology.
In fact...It may not be technology. It is probably black magic! -
I have the same card as you and had the same problem. Mine turned out to be a problem with the Sound Blaster Live! sound card I was using. When I upgraded to XP OS was when the problem started. It seems the drivers for Win2k and XP never worked right on this SB card. It tended to 'mute' the 'Line Input' when capturing. You didn't indicate which sound card you use (why should you?) but this might be looked into. I guess they might label this a 'driver conflict'. My problem was corrected by replacing the sound card, you can check this out by looking at the audio properties to see if anything is muted.
If it works, don't fix it. -
I just tried to update my ATI stuff, it jacked up everything, audio, tuner, drivers, etc.
Uninstall everything ATI and go back to something from mid last year for best results, ATI MMC 8.1 8.7 timeframes
Haven't done mine yet, not using it at the moment anyway.Want my help? Ask here! (not via PM!)
Thanks for the replys.
After trying (never successfully) to delete 8.9, I went back to the old standby fix .... Reformatting my hard drive and performing a full re-install.
I Rolled the dice again by tring to load 8.9, and it worked like a champ.
It was frustrating but it forced me to do something I needed to do anyway. Now it I have a nice clean XP Image.
BTW: I can't tell any difference in the new version.DVD technology is totally different technology.
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 14:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 11:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 13:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
ATI 7500 All in One Wonder
By justmehere in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2008, 15:08
