i got myself a freeview digital reciever 2 days ago, my prob seems to be i can be watching it then all of a suddent the screen will start to pixiate and then just turn into a blur of pixels, similar to a computer screen crash. i just wondered if anybody had any experience of digital receiver boxes, this problem or any intelligent suggestions on what i should do? i bought it on ebay and foolishly i left the guy positive feedback before i had been watching it for more than an hour.
Results 1 to 10 of 10
I have one myself and the pixelation isn't too bad even with an indoor ariel. Some channels do suffer if I move about too much but if I just sit still its normally fine. Do you get the little red box or circle ? This indicates bad reception I think.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
no i dont get a little red box, thing is, when mine starts to get a bit pixilated, it wont stop until the whole screen goes and i have to turn it off and on again. i might try one of those small indoor ariels, they sell them in wilkinsons for £4.99 and they pick up all digital stations it says. my ariel in the loft should be alright though cos this flat that i live in was only built 3 years ago, so its not an old ariel. mind you, having said that they could have just bunged in any crappy ariel.
lol, thats great, sit still all night , but its funny you say that cos it only seemed to pixilate when i moved around alot on the music channel. ive tried moving the actaul receiver into a different position that has improved it a little but still getting it.Originally Posted by VCDHunter
what box have you got? an old ondigital one? check out www.radioandtelly.co.uk there's a bunch of very knowledgeable people there! personally i'm using a Humax PVR-8000T, which has a 40gb hard drive so i get to pause live TV and record things for later/turning into DVD's. i love it!
i got a pace receiver dv3 i think it is. it isnt anything fancy. i will check that site out cheers for the link.
turned out my aerial was only giving me 32% reception (the pace box tells you that in the menu) so i have now just bought a wideband aerial and will see how much difference that makes. i think it should be good cos i am not far from crystal palace, where them massive aeriel towers are.
yeah, when we wanted to switch to freeview we had a fantastic analogue picture but NO digital reception at all. nothing. simply took down the normal aerial and replaced with a wideband aerial set up in exactly the same way and now get 68% signal and 100% quality. that's on a humax tuner which is one of the more sensitive ones.
is that an aeriel in the loft on an outside aeriel? i am keeping my aeiriel in the loft, hopefully if it works. if it doesnt then id have to see about fixing it to an outside wall, no way would i get up on my roof, not for love nor money!
up on the roof but someone else did it! luckily we had scaffold up at the time - chimney needed repairing, so he got lumbered with doing the aerial too. no-one else in the house fancied it up there though so i quite understand!
If you rent the flat it's worth speaking to your landlord.
Freeview box failure?
By aw56001 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Dec 2011, 09:22 -
Had freeview, Now it's gone!
By Squid_uk in forum Off topicReplies: 2Last Post: 23rd Sep 2009, 04:05 -
Freeview Box - File extension
By hesh234 in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2008, 14:07 -
3.5" HDD into Freeview?
By Nitro89 in forum ComputerReplies: 3Last Post: 29th Apr 2008, 10:52 -
my freeview--no event info.
By ssaamm in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2007, 14:33
