    Oct 2002
    Israel
    please try help me
    in my last ripping i made a mistake and i missed ripping VTS_04_6.vob , the movie are ending at vob VTS_04_5.vob but still dvdshrink dont let me to load the movie becuase of that. is there a way to make it load the movie , maybe to cut the end with some porgram and then load it into dvdshrink ?
    i dont have the movie anymore , so i cant rip vob 6 again.
    thanx.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    All you could do is recreate the IFOs using IFOEdit. You're up shit creek with the rest of the movie though.
    If in doubt, Google it.
  3. You can run the VOBs through the MPEG2 versions of VirtualDub or TMPGEnc since they don't use the IFO information.
    They will reencode and will take longer than DVDShrink but it will not be a serious quality hit. Just encode it down to the size of your medium (CD, DVD, etc.) if necessary.
    Oct 2002
    Israel
    which option i need to use in TMPGEnc or virtualdub ? meaning how does it called dvd2svcd , there is a lot of guides and i dont know which one to use . if you could link me up it will be great .
    thanx
