Hey guys/girls,
Well this is so confusing me man, i was wondering and i have been trying to do this for ages is, is there anyway on earth that you can copy a DVD to a single CD-R and play the single CD-R on a normal DVD player. This will be most appreciated if someone can tell me how to do this or any how else how to copy a DVD to CD-R thanks once again ppl![]()
No you cant, a DVD-Movie is from 3 to 7 GB so it is kinda difficult to fit it on one 650 MB CD. But you can convert the DVD-Movie to VCD or SVCD and you can play it on your DVD Player if your DVD PLayer supports it(check our DVD Player list).
http://www.vcdhelp.com/dvdtovcd.htm is one method to make a VCD,SVCD from a dvd source. -
If you movie is under 80min long, you can fit it on one 80min CD-R disc as a standard VCD (you can fit 90min on 90min media).
If your movie is longer than that, then there is no way of fitting the movie on one disc as a standard VCD.
Theorectically you could fit any length movie on one disc as a SVCD, but practically, a SVCD will fit even less per disc than a VCD if you value video quality.
You could create one of the variants of XVCD or XSVCD (i.e., non-standard VCD and SVCD) but this is not guranteed to play on any particular player.
Regards.
Michael Tam
w: Morsels of Evidence
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 16:17 -
Copy/Play HDDVD's from your hard drive
By joepic in forum Blu-ray RippingReplies: 20Last Post: 31st Jan 2012, 04:31 -
single audio play right through menus + highlighting selection
By Rudyard in forum Authoring (DVD)Replies: 4Last Post: 15th Nov 2008, 22:16 -
Can I copy & play from an incompatible DVD format to a compatible one?
By akersaz in forum MediaReplies: 8Last Post: 14th Mar 2008, 19:07
