I have used TMPGenc to encode my DV to .m2v and .mpa files. I have converted my raw .wav file to .ac3, and wanted to use Nerovision Express 2 to author and burn the DVD. When I choose "Add Video Files", .m2v is not one of the supported files. How can I get nerovision to accept this file. Also, how do I get it to accept the .ac3 file I have created?
Do I need to use TMPGenc to multiplex the files together into a .mpg file first?
Thanks!
Well, I ended up usning TMPGenc to multiplex the .m2v file with the .ac3 file. I then used the resulting .mpg file to author and burn using Nerovision Express. It seems to have worked okay. The DVD is playing fine on my player. I find it hard to believe that Nerovision Express 2 can't accept a .m2v file though. I thought this was a fairly standard mpeg-2 filetype. Am I wrong about that?
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
