I'm trying to author a DVD from an already existing DVDR-VIDEO_TS + AUDIO_TS folder. The problem its giving me is:
I'm using TMPEG DVD Author 1.5, when I start the burning process it suddenly stops and reads this:
""(( The structure of the appointed folder
cannot be used for a DVD player ))""
yet the files I'm using are ( VIDEO_TS & AUDIO_TS )
What am I " doing or not doing " wrong?
When I play the film using a PC DVD player. It works fine!
ANY HELP PROVIDED IS GREATLY APPRECIATED - THANKS![]()
Look at the files in the VIDEO_TS and make sure that everything in there is correct. All the IFO/BUP/VOB are matched up, all the title sets are correct and in sequential order.
Sorry to sound like an idiot ( too late ) but, How do you match them up?
They play fine in a PC DVD player + They look fine?
I dunno. I guess HELP!! -
Yes I have, but thats also the program thats giving me the problem.
Is there possibley another easy to use authoring program that might work.
otherwise I don't know -
Sorry, I didn't explain what I intended to say:
When you create a new DVD video with your burner software, like Nero, the application creates two folders automatically: audio_ts and video_ts.
I'd like to be sure you are only copying the *.ifo, *.bup and *.vob files to the burner's video_ts folder, instead of copying the directory video_ts to folder video_ts.
About audio_ts uou shouldn't do anything. It is an emptied folder. -
Are the VIDEO_TS, AUDIO_TS folders in the top directory?
They need to be inside of a folder, VOLUME001/VIDEO_TS for example, for TMPG's DVD Burner to burn them.
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
Problems in authoring DVD
By carlmart in forum Authoring (DVD)Replies: 9Last Post: 1st May 2011, 03:48 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21 -
FCP dvd authoring problems
By sksvideo in forum MacReplies: 3Last Post: 18th Mar 2008, 16:57 -
Problems with DVD Authoring
By Velocity_Girl in forum Authoring (DVD)Replies: 6Last Post: 27th Jul 2007, 05:34
