I just received my first order 50 pack of ritek go4 from rima.
I noticed the edges of these disks are rippled ....not smooth and perfectly even like the TDK DVD-R I have been using.
Also the package is the red ridata packaging...nowhere does it say go4.
Should I have any concerns here? Thank you for your experience and feedback.
the rippled edges are most likely just some glue that got out from between the layers. I've been through about 200 of these without a problem. They're probably not as good as the TDK but Ive never had a problem with them, even burning all the way to the edge.
blurred edges
By mathmax in forum RestorationReplies: 50Last Post: 2nd Jun 2010, 10:22 -
Noise around the edges.
By MaiOns in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2010, 10:52 -
Jagged edges on buttons
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2009, 11:40 -
Canon XM2: 'Rippled' telephoto picture?
By yukon33 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2008, 17:24 -
Procoder 2 - Jagged Edges
By pbar in forum Video ConversionReplies: 4Last Post: 24th May 2007, 09:32
