Hi all
I have a couple of 45 min avi's, yet when I try and convert them using tmpg it says theres 125000 frames and the jobs gonna take about 7 hours.
The avaerage for a file of this size is about 3hrs.
After re encoding the AVI using VD (direct stream copy of video and audio)the file indexing seems to be fixed, tmpg reports the number of frames correct yet when complete no sound. After more playing in VD I decided to save a WAV and AVI then join the two together after loading the wav into an editor (to amplify it) I find the Audio is only 17mins, a bit rate calculation confirms this, yet going back to the original file this will play fine with sound all the way through, why couldn't VD extract all the sound?
Anyone got any ideas whats going on and how to fix it. The files were downloaded from the web but as a continuous download and not resumed 60 times.
Any help greatly apprieciated
Cheers
Jim
Continued from earlier post
the correct number of frames is around 62000, tmpg is setup to create palvcd.
What i need more than anything is to be able to extract all the audio, it almost seems like the audio is spanned over 2 files
help help help
VLC and AVI re-indexing
By Seeker47 in forum Video ConversionReplies: 7Last Post: 13th Apr 2011, 22:56 -
audio indexing for search
By ponzonik in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2010, 11:14 -
Options for PGC indexing?
By Gew in forum DVD RippingReplies: 3Last Post: 22nd Feb 2009, 14:34 -
whats a PUB file?
By Tbag in forum ComputerReplies: 4Last Post: 12th Aug 2007, 07:21 -
How to Turn Off File Indexing in Vista
By SCDVD in forum ComputerReplies: 4Last Post: 13th Jul 2007, 05:09
