ok i encoded my movie into 2 parts. i cant burn it with nero cause it doesnt read it now that its a MPEG and not a AVI anymore. so i got VCDeasy and i add my MPEG file and then when i hit OK or GO or whatever it is. it says "i have to add at least one file". but i did?
Hi jxD, again
if you are using 1.1.6 of VCDeasy that is a trial version and has a size limit on the mpg that you add. follow the VCDeasy link and you can download the 1.1.5.2 version which is freeware.
Once in installed just choose videoCD type VCD1.1, VCD 2.0, SVCD 1.0
add your mpg, add chapters if you like and click the <GO> button. Make sure you have a blank CD in the drive and the tray is closed.
Hope this helps
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
