I live in the UK and i go tthe above sted external tv card to capture digital tv. It captures it i very good quality but the size is huge (liek 1.17gb for 45 minutes) since it is mpeg2. I have seen very good quality captures of tv programs which are xvid or avi and are also about 350 Mb for 45 minutes. My questions are as follows:
Is there anyway of making the capture software software that came with this device use avi or xvid format?
if not, is there any way of comverting to xvid without loss of quality to about 350 MB - ( i have already tried different optios with Virtualdub but as i decreased the rate in divx or xvid the quality got much worse)
Finally, if no help with the above two, is there a cheap avi capture software that i can get? ( i know of showshifter but it is about 85 dollars which is expensive for me)
any info will be much appriciated
thanks
Results 1 to 1 of 1
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 19:57 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 01:21 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23
