    Cologne-Germany
    Hi everybody,
    is there a burning tool, which splits the huge mpg-file automatically to parts each 700 MB (or 650 MB) burning size? I only know tmpg, which is not that comfortable in my opinion. Is there an easier way to split, maybe during the burning session? I´m looking forward to your answer. Thanks in advance.
    buumer
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    I don't believe such a burning program exists. However you can use this to split the movie to your desired size.
    Cologne-Germany
    Thank you for this very nice and fast tool.
    Can you give me an hint which "mb size" is perfect to burn as a s-vcd?
    If I split to 700 mb files, there is at least 50 mb room per CD-R after burning it as a s-vcd. What is the right size then to use the full CD-R
    Thank you again for your help!
    buumer
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    I'd set it for 795mb.
