Hi
I would like to know when you installed a codec on a computer, if there
any importance if you installed the codec before or after you installed a software that will read the video file ? Or it's not important.
Shouldn't matter, just do a restart after installation.
Cheers, Jim
My DVDLab Guides -
Computer, or the codec's won't be registered properly (usually).
Cheers, Jim
My DVDLab Guides
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 17:51 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
Any Programs Do This?
By sj022698 in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 18:39
