Hello, i would like to make VCD.But when i check the compatibility chart i get confused.
Some say CDR no and VCD yes.
How do i read this chart?
and how do i know if my DVD player can play VCD?
Are VCD considered CDR?
thanks
and then my friends have a DVD player. one has a KOSS and the other has a Polaroid DVR-0900
Read the manual for your dvd player.
If it will play vcd, generally that means it will play cdr.
Odds are that the cheap(er) Koss will play anything, and an expensive Polaroid may only play SVCD.
Of 5 different dvd players I have gone through, the expensive ones are the most fussy with video format. My $50 Koss will even play non-standard VCD, none of the others will.
You're going to have to burn a tester and try it. That's the only way to know for sure on any dvd player.Cheers, Jim
My DVDLab Guides -
If you make homemade vcds your dvd player must support both VCD and CDR/CDRW.
ASF/WMV - DVD-player compatibility
By Digiface in forum Video ConversionReplies: 3Last Post: 12th Jan 2009, 12:02 -
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 13:16 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 21:17 -
DVD Media & Player Compatibility
By pbisaillon in forum MediaReplies: 14Last Post: 3rd Nov 2007, 17:07 -
Oppo Player HD-Divx Compatibility
By N8theGr8 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Aug 2007, 13:34
