A simple problem - I hope!
Anyone know why, now I have my shiny new LG4081 multi-writer, that Nero doesn't recognise that the +RW disc in it contains data?
I'm trying to copy the content of the disc from the +RW disc, recorded on a Philips 890 to a -R disc so that can be played on the Panasonic DVDR. In Nero it shows as a Blank Disc! Do I have to format the disc in some way?
I don't fancy copying all the Home vids to -R's via the E50 in real time - took long enough the first time. so any help would be appreciated.
Rob
Not sure why, but I have a Philips standalone recorder and I used DVDDecrypter to rip the files and then burn with Nero. No need ot change DVDDecrypter settings just set the folder where you want to save the files and let it rip for 30-40 mins and then use nero express to burn to DVDs. Mind the +'s and -'s some don't work if there not the exact type.
Good Luck,
MareIf possible email directly with replies. -
Tried DVDDecrypter - no difference. It reports the DVD+RW is empty and yet explorer shows the folders and VOB files.
Anyone have any other ideas?
I copy +RW discs made on a philips recorder with dvdecrypter v3.17. Never had a problem with it not seeing the disc. Check your version and maybe reinstall it.
I also use the "copy disc" function in ulead dvd movie factory 2. -
OK - seems to be a media problem. Only 8 DVD+RW's out of 20 are recognised in DVDDecrypter or Nero. However, all the written data and files can be seen in Explorer! Has anyone come across this issue before and did they find a fix for it?
Philips bdp3000 blu-ray and dvd playback problem
By noelpetrie in forum DVD & Blu-ray PlayersReplies: 2Last Post: 16th Jan 2012, 16:26 -
Help with Philips MCD119 problem
By SteveHarrison1 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Sep 2010, 17:07 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
So I bought a Philips DVD player that plays DivX files, but have a problem.
By quitearush in forum DVD & Blu-ray PlayersReplies: 5Last Post: 13th Jan 2008, 03:25 -
Problem writing to Philips dvd-r.
By jackrussell in forum MediaReplies: 0Last Post: 13th Jun 2007, 06:41
