Hi All,
Apologies in advance for such as loaded question. I have several QT Mov video's, that are very high in quality at a size of 320x240.
I have tried I don't know how many ways, (TMPGenc, Premiere, Nero) to convert these to 720x576 mpegs or avi's so that I can burn them to DVD, with DVD quality. I can do the resize and conversion no problem, but the end quality is absolutely awful. They're either all pixelated or blocky or blurred.
They are watchable, but surely there is a way of taking something that is very high quality and getting it to a format that can be then burned to DVD and subseqently watched on widescreen TV's in the same quality as the original Mov File?
I have even managed to get a straight conversion to an avi in the same resolution (320x240) as the original but all you get is a small box in the middle of your TV?
Any ideas? Or is there no way of doing this at all with a huge loss of quality due to the increase in resolution to PAL Standard 720x576?
Please, any ideas?![]()
You've already discovered the results of resizing a 320x240 video to 720x576. Try it again, only this time use 352x288, which is still a valid DVD resolution but far more forgiving of smaller source resolutions. You'll probably still lose a bit of quality but not as much as your first attempt.
Audio bitrate Conversion help required.
By Shaan20Sep in forum AudioReplies: 1Last Post: 9th Jul 2011, 14:00 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
Just a conversion, no compression required
By video_noob in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 02:58 -
Resizing .mov files
By pwig in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2009, 13:38 -
ffmpregX 0.0.9y VOR to DV conversion Help Required
By Raising The Roof in forum Newbie / General discussionsReplies: 0Last Post: 15th Nov 2008, 08:17
