  1. MainConcept has released a personal video recorder software which features timeshifting, on the fly ad detection, vcd / svcd / dvd authoring and more.
    More info at http://www.mainconcept.com.
  2. And they,ve also released there Mpeg4 encoder.
    Which is crushingly slow even on a 2.6 Amd (3hrs+ for a six minute clip)
    The electronic components of the power part adopted a lot of Rubycons.
  3. Member teegee420's Avatar
    Dec 2003
    Southern California
    Well I decided to give PVR a whirl and I have to say I am thoroughly unimpressed. There's no electronic program guide, the channel line up is all wrong because it lists the composite and S-video inputs of my ATI AIW card as channels 1 and 2 respectively, there's no way to tell if you are dropping frames while recording, the options dialog isn't nearly as comprehensive as it should be and is poorly designed, I couldn't get the controls to pop up while in full screen mode, it absolutely refused to recognize the audio from my sound card's line input and the overall UI is terrible. I'll be sticking with ATI MMC thank you very much.
  4. It's made for the average idiot to use. Looks like a decent program
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Was that a compliment?
  6. Originally Posted by teegee420
