ok , i cut my movie in half and i encoded or whatever the first half , how do i get the other half of the movie to encode???i cant seem to figure it out
Results 1 to 13 of 13
now in my folder i have the one half of the movie, but i dont see an option in the tmpge program that says encode other half or anything
please wait a few days before bumping your topic. 12 minutes bumping isn't okey.
Did you cut the avi in half or just encode the 1st half using the source range feature in tmpgenc ?Originally Posted by jxD
If you cut the avi in half simply repeat what you did with the first avi.
If you used the source range feature in tmpgenc simply change the source range to encode the 2nd half.
Whaats the problem here ?
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
from what i can see u have cut a whole movie somewhere in the middle .
when u saved your first half of the film did u save it as another file name.?
if u did not - then the whole film has been overwritten by ur first cut .
if u saved it as another file name then its ok . open tmgenc merge and cut open the whole film again. set the start time in the middle( the end from the first half of the film and set end at the end of the film save output file with a different name than the original whole film - now u have ur second half or the film.
good luck[/code]
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Aug 2008, 23:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 08:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 04:38 -
FitCD / TMPGEnc question
By Seroster in forum Video ConversionReplies: 4Last Post: 3rd Sep 2007, 12:34 -
TMPGEnc XPress 4 Question
By Anakin in forum DVD RippingReplies: 1Last Post: 24th Aug 2007, 23:08
