i use a Haupauge PVR250 and a program called GOT TV to record all my mpeg2's.
I dont want any fancy DVD menus i just want the movie to start when i put the DVD in the HTPC/standalone DVD player. Is there away?
I dont have any keyboard/mouse connected to the HTPC so it would be great if the program used keyboard/commandline shortcuts because they are easy to learn the remote control.
/Anders
//Anders
ifoedit, dvdauthorgui
or tmpgenc dvd author, just set the first play to your video and you don't have to use the menu at all. -
dvdauthor is commandline driven. Will it demux mpeg2 or does it onlt take m2v and m2a files?
/Anders//Anders -
i tried bbdtools and the bddmux.exe program. but it cant demux the mpeg2. i also tried tmpgencs demuder and it gave me a "illegal mpeg2 videos tream". IS the mpeg2 from a PVR250 card not following the mpeg2 standard?
//Anders -
I tried DVD auhthor with a example xmlt config file i found on the net.
<dvdauthor>
<titleset>
<titles>
<pgc>
<vob file="test.mpg"/>
</pgc>
</titles>
</titleset>
</dvdauthor>
i then made a test.mpeg from muxing a dolbydigital.m2v and a dolbydigital.ac3 that i know works into test.mpeg.
I then started DVDauthor from the commandline "dvdauthor -o dvd -x example.xml"
i only get a "WARN: Skipping sector, waiting for first VOBU..."
Whats wrong? If i use the same m2v and ac3 file in scenarist they work fine. so i know its not the files.//Anders
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
oneclick tool to convert avi with 2 audio tracks to episodic DVD with menu
By ajamarkova in forum Video ConversionReplies: 3Last Post: 12th Mar 2008, 21:50 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45
