There are 8 compression levels in the Application. Is the quality of a backup at 'Level 1' the same quality as a backup at 'Level 8' ..or.. does the quality of the image and sound deteriorate at the higher compression levels .... thanks to those who respond.
I am assuming you are talking about DVD Shrink. And I am sure that I must missunderstand the question because it seems a little too obvious.
Are you refering to the compression percentage shown when you either back up or re-author. If you are then the answer is yes, it will degrade completely. I find that anything above 60% will survive and still look very good. The higher you go to the better you will end up with. Obviously you have the limit of 4.3Gb to look at. This is why I tend to re-author just the movie and leave all the extras, menus etc behind. This is ensure that I usually get the movie nearer 70% which is very good quality.
Hope I am on the right track here. Also, I may be wrong here but I thought the numbered level were part of the older version 2 release of the software. Check if you are using this, if so upgrade to version 3.1.7 as it gives you far better options.----Figured it out yet?
----What's that?
----Who's the best pilot!
TOP GUN (1986) -
thanks for the response. Yes, I am using DVD Shrink 2.0 I will have to get the update.
dvd shrink- how much compression...
By Bletch in forum Newbie / General discussionsReplies: 15Last Post: 20th Jan 2012, 17:24 -
Slysoft CloneDVD2 VS Shrink No Compression
By mn072065 in forum DVD RippingReplies: 0Last Post: 14th Nov 2010, 13:21 -
DVD Shrink compression method question
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2009, 12:42 -
compression and DVD Shrink
By snafubaby in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2007, 01:15 -
DVD Compression/Shrink Software Recommendation?
By Noy2014 in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 06:12
