Results 1 to 15 of 15
    Mar 2004
    i have been using cucusoft video convertor to make avi files into dvd files, then burn using movie factory 3, however some movies are taking upto 25 hours to convert, whats the fastest way to convert avi - dvd, preferably a simple method as i dont want anything to technical, thanx
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    This isn't what you want to hear but you're probably better off sticking with your current method. There is nothing fast or simple about this particular conversion. You'll have a whole new set of problems without much increase in speed if you attempt a new process. Stick with what works for you.
    Mar 2004
    ok, will do....is it ok to still use the pc whilst its converting? or could this decrease quality? or cause errors, i dont mean run games or anything like that, i mean like is it ok to still surf the net and download files whilst im converting an avi - dvd
    Mar 2004
    i noticed some stand alone dvd players now play avi files, mpegs etc, directly off data discs, one i was looking at in particular was one made by kiss technologies (think it was about £170) are these players any good? and is playing avi files on them as simple as it sound? or is encoding - converting still involved?
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    As long as the AVI falls within the specs of what the player handles, you should be fine, but since "AVI" can contain just about anything, don't expect every AVI you find on the web or thru P2P networks to work without problem.
    I've never found using the computer while encoding affecting the quality of the encoding. It's just that it's a pain trying to use a computer that wants to use 100% processor for encoding...
    /Mats
  6. Member teegee420's Avatar
    Dec 2003
    Southern California
    Surfing should be fine. If you are downloading files, try not to put them on the same drive your converted mpeg is writing to. It will probably slow things down a bit. Nothing major, but that way your hard drive won't have to work as hard.
    By the way, I've heard some good things about the KISS players. Might be worth looking into. That would save you a lot of time re-encoding and losing quality. Make sure you read up on the exact type of files it plays.
    Mar 2004
    yeah they sound good, you could fit more movies onto a dvd, would be cool
  8. I am looking at getting one of those kiss players also, they accept wireless pci cards also so you can stream from the pc apparently.
    If it's wet, drink it
    My DVD Collection
    Mar 2004
    some of my avi's are taking upto 94 hours!! to convert to dvd and im getting like 0.5fps convert speed, surely this isnt normal, can it really take 94 hours to convert one movie? must be a faster way
  10. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Extract audio with VirtualDub: 5 min max
    Decode audio to wav if in mp3 with CDEx: 10 min max
    Encode audio to ac3 with ffmpeggui (if not in AC3 already): 10 min max
    Encode AVI to M2V with MainConcept (resizing and frame serving with VirtualDub): 1.4 x real time.(2-3 hrs)
    Author with IfoEdit: 1/2 hour
    Create DVD image with imgtools classic: 10 min
    Burn image with DVDDecrypter: 20 min
    Worst case total: 4.5 hours
    (Intel Pentium IV 1700MHz system)
    /Mats
    Mar 2004
    is there a guide in detail on how to do all that? or is it pretty simple?
  12. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I don't think so, but all I know in this area, I've learned here at DVDRHelp. Basically I've read and tried every possible guide that even remotely fit my purpose, and picked a little wisdom here and there along the way to come up with my own process.
    /Mats
    Mar 2004
    if i download all the software you mentioned, then tried it myself, is it fairly straight forward, or am i better looking for a guide for each individual step u mentioned? thanx for the help btw much appreciated
  14. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Since it's all freeware utilities (except for MainConcept), the workings and user interfaces might seem a bit daunting, and takes some time getting used to, but don't let them scare you! It's fairly straight forward, yes, but not something you'll learn during a coffee break either. But if one DivX takes you 94 hours to complete, while it takes me 4.5 hours, you can safely spend 89.5 hours trying to figure stuff out and still finish a movie in the same time as before! You will learn a lot in the process.
    /Mats
  15. If you give a look to some of these guides,
    https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=AVI+to+DVD&ho...or+List+Guides, I'm sure you'll find yourself the right way of doing things correctly.
    Even better, start by loading your AVI file with Gspot and take the information about which video codec and soundcompression is in the file, then you certainly will be able to restrict the number of the guides a lot.
