so i dont often make a post but i have been searching for like 3 days. i need some help...
I have no problem downloading avi and mpeg files and splitting them with virtualdub1.5.10 and burning them to a vcd..
I am now trying to find a program(s) that i can rip a DVD preferably to a mpeg or avi file of some sort.. is this even possible??
I have used DVDDecrypter to rip a dvd and i got multiple .vob files.. i searched thru probably 12 different programs to try and convert .vob files to avi/mpg files.. some wont work because of audio problems.. ie: virtualdub-mpeg2 will work.. but not on "direct steam copy"... and i do not have enough memory to save it by "full processing mode" being as the file will be around 10 gb and i doubt that would even fit on a vcd newayz..
point being is i know how to do this stuff but cannot find a program that will work..eazyvcd1158 seemed like it would work... but everytime it reads the cd it closes out.. so im stuck here..
i appreciate any help anyone can give me thanks alot!
In Vdub you need to specify a compression type when using full processing mode (video > compression) before you save. If you don't then it will save it uncompressed which is very large.Originally Posted by twiztidserkilla
If you're wanting to create a VCD then use DVD2AVI instead, it will create a small frameserver file which you can open with TMPGEnc. Look it up in the guides.
Of course you can just frameserve from Vdub to TMPGEnc as well. Frameserving allows the video to go direct from one program to another without saving an intermediate file. Here's a guide."Art is making something out of nothing and selling it." - Frank Zappa -
It always matters.Originally Posted by twiztidserkilla
Eazy VCD.
I gave it a try three days ago and install/setup took about FIVE MINUTES! Make sure to read Sefy's guide about (link somewhere here).
I had my first ripped DVD movie in mpeg format in exactly TWO HOURS AND FIFTEEN MINUTES after installing/configuring the program!
It's that easy. -
I Think you are referring to this guide about EasyVCD
http://sefy.iwarp.com/guides/direct6.htmlEmail me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
dvd creation for dummies
By Yerbury in forum Newbie / General discussionsReplies: 14Last Post: 22nd Dec 2010, 14:29 -
Need help please, HD-DVD backup for dummies
By stblob in forum Authoring (Blu-ray)Replies: 7Last Post: 7th Aug 2010, 11:20 -
Somewhat complex DVD MENU construction(questions) for(from) dummies - Pt.2
By Gonz0ne in forum Newbie / General discussionsReplies: 25Last Post: 21st Oct 2008, 02:59 -
Somewhat complex DVD construction for dummies - Pt.1(questions, not guide)
By Gonz0ne in forum Newbie / General discussionsReplies: 7Last Post: 16th Oct 2008, 05:08 -
Looking for a DVD editing program for dummies.
By träskmannen in forum Newbie / General discussionsReplies: 6Last Post: 10th Aug 2007, 15:48
