Results 1 to 9 of 9
Download and install ForceASPI. It installs an older version of Adaptec's ASPI layer. DO NOT download the latest ASPI from Adaptec as it may not work.
ForceASPI will solve your problem. Set your CD burner to generic-mmc-raw and you should be fine... -
Burnatonce is one of my favourites when it comes to burning CD images. Can use both ASPI and SPTI (?)
/Mats -
OK I was able to use the ForceASPI and it burned VCD and I was able to play on my stand alone DVD player. Woohooo.
Now...How can I increase the quality it was very "blocky"???
I started with a WMV file and then converted to MPEG should be going to AVI or another way????
This forum is *awesome*
Y -
Since VCD specs are pretty limited (and does not allow for tweaks), there's not much you can do to make the quality better, other than getting better source material.
Only other route is CVD or SVCD which both are mpg 2 video formats.
/Mats
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 15:22 -
burning and authored mpeg to dvd?
By just in forum Newbie / General discussionsReplies: 21Last Post: 12th Dec 2008, 10:06 -
help,, for burning a dvd movie and player at sony dvd player.
By flowerhorn in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2008, 10:12 -
AVI to MPEG conversion and DVD burning
By mc-help in forum Video ConversionReplies: 2Last Post: 5th Jan 2008, 17:08
