  1. My CPU Temperature is 60C according to bios. Is this OK, as I intend to leave my PC overnight encoding & downloading etc . And what temperature should I get worried about ? I have large fan on CPU & incase. Is it safe to leave on for long periods ?
    AMD TBird 4
    Gigabyte 7VTX
    40 gig IBM 7200
    Jan 2001
    Vancouver/Portland
    60C is pretty hot but it works. Mines is usually 57C, give or take a C... if it's hotter than 63C, then that's something to think about... =|
    <font size=-1>[ This Message was edited by: Jeomite on 2001-10-25 02:52:02 ]</font>
  3. No its not okay I suggest you get a new cpu fan
    I burned mine out at 76 degrees
    Now i'm on a 1.4 overclocked to 1546 and my bios tempature is 40-45c
    anything higher than 138f is something you have to worry about
    <font size=-1>[ This Message was edited by: septor on 2001-10-25 02:54:29 ]</font>
  4. A tempature of 60 C is TOO HOT! It still is not critical, but you are shortening the life of your CPU if it runs that hot frequently. The ideal tempature should be 50 C or less.
    My 1200 Mhz T'Bird runs at 119-128 F under load. For what its worth the monitoring software that comes with my ASUS board has the default CPU temp alarm set at 140 F.
