  1. I'm looking for a good program just to lable the spines of my DVD-R's and idea's ?
  2. For regular jewel cases or the movie cases?
  3. Regular please !
  4. I would really like one that gives you the outline of where to cut
  5. I created one in MS Word, and it has an outline for cutting. You can overlay graphics into the spine area but I use it for just titles in most cases. Have you thought of using an MS Word template before?
    Apr 2002
    The State of Frustration
    Surething also has templates for that as well.
    Hello.
  7. yeah I just want Text, Thanks Alot
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I just scanned one of those pre-cut sheets from some crappy "Create your Own" programs....the ones that DONT allow importing of images or text. I place the scan of the complete sheet into Image Composer and do my stuff over top of the scan....which handily has the outline of the DVD insert. I also use A4 paper...MUCH easier.
    Scottie...if you want the scan...send me a PM.
