Hi, is there any big differnce betwen a photo VCD and a photo DVD, i mean quality, or it`s just the numbers of pictures??
No big photo quality difference, photo vcd is 704x480/576 and photodvd is 720x480/576.
But if you want a slideshow with transitions it will look better on a dvd because you are then making a video and vcd has only 352x240/288 resolution and dvd 720x480/576.
Does SATA make big difference for DVD burner?
By sdsumike619 in forum ComputerReplies: 6Last Post: 28th Nov 2008, 20:21 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
Big difference viewing backup on 32 inch crt tv and 42 in HDtv
By freebird73717 in forum DVD RippingReplies: 20Last Post: 9th Jun 2008, 19:52 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 13:59
