  1. Can anybody help me please. I need to put my voice(like comments) in a video. is that possible?????
    Apr 2003
    Largo, FL
    You could load the audio into an audio editor (Goldwave would work), then load your voice comments in and mix the two. If you use Studio 8 (or 9) then you can add an additional sound track with your voice comments.
  3. thanks, is there any link, or a useful help guide???
    Apr 2003
    Largo, FL
    Goldwave version 5.06- http://www.goldwave.com/
    Studio 9- http://www.pinnaclesys.com/
    Don't know if there's any guides for specifically adding voiceovers, but you can search the guides to the left.
    Dec 2003
    Davenport,Iowa
    Does anyone have any advice on a microphone brand to use for adding voice.How good of Quality of a mic?
