Okay, I have a really weird problem now.
I made a SVCD (2 minutes, 23 seconds) and tried playing it on my Apex AD-703 and it worked fine, or so I thought...
At first, the audio is not synchronized. It comes in about 1 second late. The video is playing fine. Then, the video actually slows itself down so that the audio can catch up! That is very annoying because the first second of video has a cool startling audio "bang" effect to go with it and I can't hear it until about 1 second later. Then the framerate drops, then the audio catches up, and it plays fine.. for now.
After like 45 seconds or so, the same thing happens. I hate it because it's really annoying. My guess is that my DVD player is having problems with the 3:2 pulldown on playback and starts playing the video too fast, then realizes that it is doing that, then slows down to sync with the audio, then plays fine for awhile, then it does it again.
Help please! Thanks.
By the way: Here's what I'm doing -
Premiere 6 (.avi 23.976fps) --> TMPGEnc (MPEG2, 3:2 pulldown on playback) --> demuxTMPGEnc --> muxBBMPEG --> bin/cueVCDImager --> cueNero to CD-RW
P.S. - PowerDVD freezes when I try to open the AVESQ00 (or whatever) mpg file that is on the SVCD I made.
AP Enterprises Ltd. -
The problem lies with TMPG when the audio and video mix it does somthing that can be fine for some players but doesn't work as good with APEX, just use a diffrent encoder, I use XINGMPEG (u can get the full version with a file sharing prog. I use KaZaA http://www.download.com ). I had the same problem but looked around on VCDhelp.com
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
