What I want to know now is how to figure out if my computer recognizes the external DVD writer?
First of all, it says "Please insert Blank Disc" so I insert it into the disc drive (of the external DW) and it continues to say "Please Insert..." So I was thinking that I may not have actually installed it to my PC, because I did not go through any installation programs. The only installation of the Disc writer was plugging everything in.
What do you think is going on? Thanks in advance!
Need more information like what are you're computer specs and what operating system are you using? Is there a installation CD that came with the burner? If there is then go ahead and install it. If not look below:
Windows 98 go to control panel>click on system>device manager> then look to see if the external dvd burner is there.
Windows 2000 pro go to control panel>click on system>click on hardware tab> device manager> then look if the external dvd burner is there.
Or look at Plextor's website:
http://www.plextor.com/english/support/plexhelper/windows_usb.html
Plextor PX-B310U
By ruktuim in forum DVD & Blu-ray WritersReplies: 1Last Post: 29th Apr 2009, 13:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Plextor PX-AV200U or ???
By wtsinnc in forum Capturing and VCRReplies: 4Last Post: 11th Nov 2008, 13:46 -
Plextor PX-760A
By SCDVD in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 01:24 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
