Does anyone know how to get into the service menu so i can change the region to multiregion?
i could go to service menu using the steps mentioned in the sony dav-fc7 hack list. but after that i was not able to use my remote. i tried pressing all the keys on remote but it did not work. it will be good if anyone know what to do next after you get in to SERVICE menu.
thanks -
Most Sony and JVC units can not be hacked.
Google is your Friend
Sony DAV-BC150/BC250 Hack code
By Christina812 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Aug 2009, 18:04 -
Sony DAV-DZ265K- multi-region code required.
By alllleg in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Mar 2009, 07:12 -
Question, Sony DAV-DZ830W hack?
By scandragon in forum DVD & Blu-ray PlayersReplies: 6Last Post: 28th May 2008, 14:00 -
Sony DAV-HDX265 ALL REGION/TV SYSTEM HACK----HELP!
By DVD superfreak in forum DVD & Blu-ray PlayersReplies: 6Last Post: 20th Feb 2008, 12:57 -
free region needed to sony dav-hdx465
By churu in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Dec 2007, 14:07
