Hi
I have a avi file with a medium quality that have these properties (from avicodec)
File : 699 MB (699 MB), duration: 1:03:07, type: AVI, 1 audio stream(s), quality: 59 %
Video : 655 MB, 1452 Kbps, 29.970 fps, 512*384 (4:3), XVID = XVID Mpeg-4, Supported
Audio : 43 MB, 96 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
I want to convert it to vcd or svcd
What do you suggest i choose between the two ?
And what aspect of the original file make you go toward one format or the other
thanx a lot
aspect ratio would have no bearing .. depends what you want to play it back as is really only question ..
i would pick svcd as first choice ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I'm sorry i don't understand what you meanOriginally Posted by BJ_M
I see you would choose SVCD, i would like to why you would choose this one so next time i can do the same deduction that you did and do the right choice
thanx -
its higher quality
you can have the same aspect ratio in scvd as vcd -- so i didnt see how that would mater .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
What make you think it is high quality ?Originally Posted by BJ_M
the fact that the Video have a bitrate of 1452 Kbps ?
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
