Just wanted to know what the order should look like (in the bios)
I have a DVD RW and a CD RW/DVD Rom. I just wanted to know hwo the order should look like with primary slave/master slave etc. I have it on default at the moment, but my dvd burner (liteon LDW 401S) isn't burning dvd+rs (with nero) and I want to know if this may have something to do with it.
Thanks,
Mare
If possible email directly with replies.
Here's the log file as Nero stops at "checking discs"
HUGE ARSE COOKIES TO WHOMEVER HELPS. Is there anything wrong this log file?
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 4/23/99 10:22:00 PM
ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/03 7:18:06 PM
Nero version: 6.3.0.3 (Nero Express)
Recorder: <LITE-ON DVD+RW LDW-401S> Version: ES0J - HA 0 TA 1 - 6.3.0.3
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST RW/DVD GCC-4120B>Version: 2.00 - HA 0 TA 0 - 6.3.0.3
HL-DT-ST RW/DVD GCC-4120B (Target 0, D
: Autoinsert Off, DMA Off, Disconnect ?, SyncDataXfer ?
LITE-ON DVD+RW LDW-401S (Target 1, E
: Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 24117248 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 127MB (130216kB)
Free physical memory: 22MB (23372kB)
Memory in use : 80 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.3.2004
UDF/ISO compilation
6:16:21 PM #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
6:16:21 PM #2 Phase 114 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed (no file modified)
6:16:21 PM #3 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
6:16:21 PM #4 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Video files sorted
6:16:21 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
6:16:22 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
6:16:23 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3882
6:16:23 PM #8 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
6:17:00 PM #9 Phase 40 File dlgbrnst.cpp, Line 1800
Aborted by user
6:17:00 PM #10 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
6:17:00 PM #11 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: LITE-ON DVD+RW LDW-401S;
CD type reading failed
ATIP Data: ?
6:17:00 PM #12 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD+R/RW.)
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 3/11/02 10:55:38 AM
File 'IoSubsys\DRVWPPQT.VXD': Ver=3.10.36a, size=228223 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 4/23/99 10:22:00 PM
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 4/23/99 10:22:00 PM
Registry Keys:
- MaryIf possible email directly with replies. -
Your IDE setup looks fine based on log file
The writing failed due to wrong media in dvdr drive is what it says ..
Either the wrong type or it is not blank or it is a failed disk .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Error Checking CD's
By Nitro89 in forum AudioReplies: 30Last Post: 8th Nov 2009, 23:58 -
Error checking software?
By Lucifers_Ghost in forum ComputerReplies: 6Last Post: 17th Mar 2008, 08:01 -
By JimboM in forum Authoring (DVD)Replies: 3Last Post: 26th Feb 2008, 13:18 -
Checking video files
By unknown12 in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2007, 02:32 -
Checking CPU temperature
By Rudyard in forum ComputerReplies: 6Last Post: 22nd Nov 2007, 17:18
