Greetings.
I am brand new at this so please bear with me. I use the well-known sequence DVD Shrink --> DVD Decrypter to rip and burn a disc. When I try to write -using DVD Decrypter- on a DVD-RAM disc using my DVD-RAM capable Panasonic DVD writer, DVD Decrypter gives me a message stating that the target disc is not empty (even though it is!) When I try burning directly on a DVD-R it burns just fine. I have tried a couple of brand new single-sided and double-sided DVD-RAM discs and I always get the "Disc not Empty" message. I know the answer is probably obvious, but can anyone point it out to me? Do the RAM discs need to be formated or something? Or do the DVD Decrypter settings need to be changed in some way? I already have the option of "erase target media" checked, but I don't know what else to do. Help!![]()
Why don't use just use DVD-R discs all the time...DVD-RAM are too expensive and already a thing of the past
Well, eventually I suppose that is what I will do. I just was using RAM's because they are re-writable and I wanted to test some alternative ripping/burning combinations until I found one I liked best. Also, I own a Panasonic DMR-E80, and having a RAM-capable writer gives me compatibility if I want to move projects back and forth betwen the two.
question regarding DVD Fab Decrypter
By Bamahusker in forum DVD RippingReplies: 2Last Post: 3rd Mar 2010, 17:02 -
DVD Decrypter Question
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 28th Jan 2010, 04:56 -
dvd decrypter/dgindex question...
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2009, 09:35 -
New to board, DVD fab HD decrypter question......
By marine89052 in forum DVD RippingReplies: 2Last Post: 27th Mar 2008, 20:24 -
DVD Decrypter Region Question
By nickolasj80 in forum DVD RippingReplies: 2Last Post: 21st Jun 2007, 19:26
