After I backup my DVD, I get an iso or img file, at 4.3 gigs. I like to store these files incase I need to make another copy later. Here is my problem:
I have 4 hard drives: 120GB External (just for DV Video), 80GB (holds windows, programs, games, etc) 8GB (holds music, not big enough for iso files), and 40GB (want to hold my iso movie files)
The problem is that I want to use the 40 gig, so I transfered to NTFS to hold the big files. But that hard drive has a problem when used as NTFS. I get errors and such. So I have to convert back to FAT32, is there a way that I can cut up the iso? like to gl files so that I can burn it in DVD Decrypter without having to put all the isos back together. Ive heard that you can cut it into 3 or 4 gl files, and just select one of the files to burn the whole movie. Can anyone tell me how to do this, or how I can backup those isos without going back to ntfs? Thanks
Partition Magic 7 or 8 will patition drives how you like .
Convert fat32 to NTFS or NTFS to fat32 and will prtition drives for you.
Try a google search for Partition Magic -
hi all i still cant figure it out how to post or where? I have a quick question can u put two movies in one dvd-r disc?
Tvox
Goto Forum at top of homepage and click on Newbie then New Topic
DO NOT ask questions on someone elses post.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
New here - Quick questions
By ImportGuyR34 in forum Authoring (DVD)Replies: 6Last Post: 10th Mar 2011, 07:11 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 17:14 -
Maybe some quick advice
By jfharper in forum ProgrammingReplies: 0Last Post: 9th Nov 2007, 22:49 -
Quick Help On Audio
By dbanga in forum AudioReplies: 2Last Post: 17th Jun 2007, 15:35
